Trailer Axle Size ? 1999 Magic Tilt
OneLuv1979
Hey guys im about ready to buy some new hubs since my lug nuts on my trailer are so damn rusted on ...
Its a 5 lug 4.5 hub ..... I need to know if there is a common axle size that anyone can pin point to my trailer ...
17ft boat ....
bruceb58
Re: Trailer Axle Size ? 1999 Magic Tilt
You just need to pull the hubs and see what bearings are in there...or measure the axle size yourself after pulling off the hubs.
Silvertip
There is a bearing size/part number chart as a "sticky" at the very top of this forum. If the outer bearing is 1-1/16 and the inner bearing is 1-3/8 then you very likely have a 3500 pound axle and you need 1750# capacity hubs that accept those bearings. Anything other than that will not match the axle spindles. It is highly unlikely with the size boat and trailer you have that this would be a lighter axle (1-1/16 both bearings), or any heavier than 3500#. You do not need to go to a marine dealer to buy the hubs and bearings. If you have a farm store in your area, start there. You'll pay much less for the complete assembly with bearings installed.
