bruceb58
- Mar 5, 2006
- 30,792
Re: Trailer Bunk Brackets
Grinding off welds is a time consuming effort. You also have to be careful here because its a tube trailer(pieces of junk if you ask me). The tubes are usually much thinner than if it was a C channel trailer.
Welding the new ones on will be the easy part.
With so much that can go wrong here, the estimate looks fine to me.
And for future reference, never buy a tube constructed trailer.
Let's see 8...brackets, removed and welded. You can't just cut off the bracket flush with the frame because the new one needs to sit where the old one was. I can see a lot of time removing each of these brackets. You just can't cut them off. That would be easy if you could. Could easily be 30-45 minutes per bracket to do that which is 6 hours right there.I could do that in 3-5 hours
