Recently purchased boat: 1992 Sea Nymph FM 160 - 1993 50 hsp Evinrude - 1993 Haul Rite Trailer - I have not had it wet yet.
I've posted another thread recently on plastic bunks and mentioned my roller questions but I thought I'd start another one with this one more centered on trailer set up than materials.
Regardless of what I do with my bunks (wood or plastic) I'm not quite sure my rollers are set up correctly and thought I'd ask for some opinions based upon my photos.
My 2 x 4 bunks are around 7 ft. long and have fixed brackets supporting them. (The angle is adjustable but not height) I have two standard 8" black rubber keel rollers. One at the end of the trailer and one up at the bow past the bunks. Those also have fixed brackets. With fixed brackets I would think this would mean it was set up for this boat to begin with but not sure if the boat manufactures were setting up packaged rigs like they are today. Anyway, to me it looks like the bow roller is holding too much weight. I crawled under it today and I could push it off the rollers but there is definitely some weight there. I guess that is why the front roller is flattened out and needs to be replaced. The rear roller is in good shape and is about 2.5 inches below the boat as it sits on the trailer.
I first want to find out if this set up is normal. If it isn't I'm hoping to get some suggestions on a remedy. If it is, I am going to replace the rollers with either those poly v-keel rollers with end caps or maybe even those self centering type. If you use the self centering type, do you need one only on the back or should you use them on both? I appreciate any and all comments and suggestions.
Thank you
Thank you
