minuteman62-64
- Apr 12, 2011
- 1,350
Haven't worried about this much since I've never trailed my boat when lights have been needed. Now that I have some more time I expect to be trailing my boat when it will be necessary to use the lights. So, I want to comply with both the California DMV and the Federal DOT requirements.
Checked out some trailers at the Shelter Island launch ramp this week. Lighting systems are all over the map. Some I'd question if they could be legally towed at high noon. I was, however, impressed with the creativeness of the fellow who had duck taped an old flashlight to the rear of his trailer frame
Anyways, first thing I want to figure out is the front side marker lamps. My trailer is less than 80 inches wide so, as near as I can determine they are not required under California DMV regs. However, they are under the DOT regs.
Here's a picture of my current rig. #1 shows existing rear brake, turn, tail and plate lights and also rear side marker lights incorporated. #2 shows existing, inoperable front side marker lamps. I just removed these today, since I read on this forum that, even if not required, if you have them they are expected to work..
My question is, can I relocate the front side marker lights to the area shown as #3? This will keep them high and dry during launch/retrieval.
