Trailer light problem
flathead50
My tail lights will work, also brake lights will work, But if tail lights are on and I apply the brake, all trailer lights go out, Whats causing this, Everything was fine the last time I had boat out.
Thank you
JB
Re: Trailer light problem
You have lost the ground connection.
rndn
I agree 100% with JB, sounds like a grounding issue, or lack thereof.
kenmyfam
Ground, ground, ground !!!!!
The plague of the trailing classes !!!!
cmchesse
Run A separate ground from each light to the wire harness. Do not count on a ground hooked to the trailer. It may work for a while or a from time to time but it will never be suitable.
Benny1963
mine was doing same thing clean all ground connections worked for me
flathead50
Problem solved, Thanks to all, Special thanks to cmcheese , That was a good tip.
