Trailer lights quit working!
7lazy77
I just recently replaced all trailer light housings (rear & clearance) with new LED's. Did not replace any wiring since it all looked good still. Everything was working great until I took the boat in to wash it at the carwash & now I have lost ALL trailer lights. I know the problem is on the boat trailer since I hooked the tow vehicle up to another trailer & those trailer lights worked fine. How & where do I begin tracing the problem? Thanks
Re: Trailer lights quit working!
Ayuh,.... Have ya got a Test light,..?? yer gonna need 1,....
Then just follow the power, 'n make sure there's a Solid Ground,...
I find Leds to be very temperamental to ground connections,...
Starcraft5834
I'd suggest you run new wire in the frame and be done with it.. rule out chasing shorts in the wire.. tie new wire to old in front (tightly) :) then pull it through.............
Mi duckdown
99.9% it is always the ground. The ball to trailer is NEVER a GOOD ground. Just adding in.???
