Re: Trailer Lights
First,I'd plug in plug in the car into a different trailer to make sure the problem is in the trailer,then all I can say is check the usual things such as grounds (funny thing grounds, had a car once with a bad ground, stepped on the brake and the front parking lights would come on but no brake lights ), bulb sockets or a freyed wire harness.Sometimes it's a whole lot easier to just put in a whole new trailer harness for 7 or 8 bucks then to spend hours running down all the possibilities.Just make sure you use solder and shrink tube on the splices and not the crimp spicers that come with the wiring kits. And don't forget the dielectric grease in the bulb sockets.Good luck again.R.B.<br /><br />------------------
