trailer lights
river rat1
here my problem hope some one can help I replace all the wire on the trailer ever thing works but when I have the lights on I push the brake the light go off not get bright like they shold any help ty
SWD
Re: trailer lights
Wired up incorrectly and/or a poor ground.
Grandad
Re: trailer lights
Yup, bad ground. The tail light and brake/turn signal light negatives are connected together via the frame. As long as the frame is well grounded, the circuits function independently. If the frame ground is poor, the tail lights will backfeed through the brake/turn signal filaments in the trailer and then through the filaments in the tow vehicle to get to the tow vehicle ground. Because the filaments in the tail lights are not as bright (have a higher resistance) the current that they carry is not enough to light the brake/turn filaments, so it goes unnoticed. When you step on the brakes or apply the turn signal, the tail lights lose their backdoor ground path and they go off. When things get weird, it's usually the ground that's causing the problem. - Grandad
river rat1
Re: trailer lights
I just check all the grounds are good I even try moveing them no luck I have trun singles bake lights works when my head lights are off but when I trun my lights on I have my running light but when I push on the braks they go out
Re: trailer lights
Ayuh,.... Hook a set of booster cables, 'tween the trailer frame, 'n the tow unit frame,...
You've got a Bad ground,... The Ground path has to go All the way to the tow unit's Battery,...
Mi duckdown
Re: trailer lights
You are not using the ball to the trailer as a ground Are you.????
Pony
Re: trailer lights
The bad ground could be on the tow vehicle side and not the trailer. Whenever I wire my trailers I run an independent ground to each light and the connector.
I have had problems like this before and ended up tracing the bad ground to the truck side. Redid the ground right behind the harness on the truck and I was good to go.
Re: trailer lights
Best idea, guarantees you that the trailer will always have a perfect ground... assuming your connectors are sealed from the elements, shrink tube and a dab of silicone goes along way for boat trailers, IMHO
