Trailer rollers
ewenm
Hi All<br />on a roller trailer should the side rollers be taking any weight or should they just touch the hull for side to side support and all weight be on the keel rollers<br /><br />Regards Ewen
tashasdaddy
Re: Trailer rollers
properly space they should be under the stringers of the boat. they should carry about 1/3 the load each. you don't want all the strain on the keel. with all the weight on the keel rollers you are putting an extreme amount of stress in just 2 or 3 places. distribute the load as it is in the water, under way, mid ship back. the front roller and bow stop will carry that portion.
Re: Trailer rollers
Ideally,....... Every Roller would support the Exact Same Load...........<br /><br />Alot of Keel Rollers are only a 5/8th" axle,........<br />They Won't Take the Weight......Unless we're talking about a Rowboat.......
ewenm
Re: Trailer rollers
thanks for the help the boat has been moored all its life untill recently, now ive aquired a trailer and have added more rollers, the boat is a 1993 Bayliner Ciera 2255 about 4000+ pounds the previous owner only had 8 rollers other than keel<br /><br />(4 pairs) so i removed them and replaced them with 4 sets of quads and have moved the 4 sets of pairs further forward i still want to add an additional set of quads between the existing giving 32 instead of the 24 now (excluding keel rollers of which there are 6)<br /><br />Regards Ewen
