Have an early 1980's 14ft Fiberglass runabout, you know, closed bow, windshield etc, that will soon have, if all goes as planned, a 50 or 55 hp, mid 80's Johnson or Evinrude on it, but I need a new trailer, so looking at a galvanized , single axle, total length about 18+ft, the tires on it are almost new, 4.80 x 12, Carlisle Sport Trail rated at max 990 pounds each. Will they be okay with my boat/motor setup? The seller had a 14ft welded aluminum with 40hp 1995 Merc on it. but guessing his boat was a lot lighter than what I will have on it. Also like it because it will be lower than with bigger, higher rated tires found on most trailers this size, which are about 2-3 inches bigger diameter, so the smaller tire diameter will help in launching as the boat ramp isn't very steep, so won't have to back tow vehicle so far into the water to float the boat. Would I be okay, tire wise?
