Trailer tires.
FLATHEAD
Need new trailer tires. Any recommendations? I do mostly local runs with a few longer on the highway trips per year.
Size is 175/ 80 R13
jimmbo
I too really like the Goodyear Endurance. Before them I had the Goodyear Marathons, and they lasted over 15yrs
bajaman123
MANY very good tires made in China...in fact ALL of the OEMs have state-of-the-art tires being made in China. Yes, there are the cheap, "China Bombs" but they are immediately obvious by their price.
I have had excellent results with Carlisle tires, the 'high end' version. Goodyear Endurance is another one with a fan following.
Lou C
Bias ply vs Radials:
Bias is good for local towing, rougher roads, lousy boat ramps, because the sidewalls are usually about 2x as thick as a radial. Most radials other than a full steel tire have only a 2 ply polyester sidewall. A Load Range D bias tire has an actual 4 ply sidewall (but rated as an 8 ply tire).
Bias also has no steel belts, so when they fail they don't beat the trailer and boat up with steel strands
Radials advantage is they run a lot cooler so if you tow at high speeds especially in hot weather they are definitely better than a bias tire. However, if you can keep your towing speed to about 55-60 mph I don't think you'll blow up a properly inflated and not overloaded bias tire.
Last thing, a radial tire is a lot more complex to construct than a bias tire. The bonding of the steel belts to the carcass is critical, and if not done right centrifugal force will cause a failure. Sometimes you see a cheap radial tire not even mounted, a spare that is, that blew up due to poor bonding of the steel belts to the internal structure.
Local towing, bias is fine if it meets your load requirements.
Highway towing, do not buy cheap radials, I would use the GY Endurance, or maybe the Kenda Karrier if the GY wasn't available. Other choices are Carlisle, or Hankook. Kenda has been in business a LONG time, they are based in Taiwan and manufacture tires all over SE Asia and also have some operations here in the US. Last set of tires I got from them were made in Vietnam! Others, Taiwan or China. No failures with any of them not even a flat, and that's over 20 years of using them.
aspeck
Lou C gives a good breakdown of trailer tires. Chose wisely, Grasshopper. LOL!
dingbat
Good friend owns a tire shop that caters to the local landscape and construction trailers.
I typically install the tire he recommends at the time. Currently have Carlisle Radial Trail HDs on both trailers.
FLATHEAD
I’m going to give the Kenda Karriers a try.
Couple endorsements here. They seem to get good online reviews for what those reviews are worth🙄
Lou C
Sounds like you got your money's worth though. A bias tire won't do that because there are no added belts to come loose but sure you can get a blow out when the tire overheats.
The other thing is this, most people have no idea how much their towed load weighs, unless you actually weigh it. So you don't know how much of a safety margin (if any) you have with your load on the tires you have. Vehicles have at least a 25% safety margin meaning that at full load your tires aren't loaded beyond about 75% of their maximum capacity. Many trailers only have 10% so that means even when properly loaded the tires are loaded to 90% of their capacity. About the only way you can improve this depending on what size your wheels/tires are is to go up to 16" rims, that gives you much better options.
