trailer wiring
harper1
I have wired my trailer and everything works except when I turn my truck lights on. then know brake light?
Re: trailer wiring
Ayuh,... You have a Bad Ground...
Bob_VT
Re: trailer wiring
Use some real coarse sand paper and cut through the rust to bare metal ;)
Welcome to iboats!
Silvertip
Re: trailer wiring
If you have any bolted joints in this trailer such as a tilting mechanism then that joint needs to have a ground strap that electrically ties together the two sides of the joint. If the trailer is extremely rusty you might be better off running a separate ground wire to each lamp assembly.
jmfrost
Re: trailer wiring
Had similar issues with my last trailer. Finally discovered that it was depending on the ball on the hitch as a ground. Created my own ground by crimping an, "eye," on the ground wire, drilling a hole in the trailer in a hidden spot, sand it down to bare metal, and ran a ground to each light from there. Don't forget something like dilectric grease to keep corrosion from accumulating.
bruceb58
Re: trailer wiring
If the trailer was relying on the ground through the ball then what you did by running separate grounds to each light did not solve the grounding through the ball problem. You have to run the ground through the trailer to vehicle connector and make sure both the trailer and vehicle side have good grounds.
Not necessary at all to run separate grounds to each light. The problem with doing that is that you have doubled the number of wire connections that you now need to worry about. If you start with good bare grounds at every light, you will never have a ground problem at a light assuming you have a trailer whose frame isn't a bunch om metal bolted together.
marlboro180
Re: trailer wiring
Good point Bruce, but if one solders the spliced connections and welds the frame up and brazes on ground eyes near the lights then it is pretty valid to run separate grounds to each light.
