tramsome has a bunch of unused screws in it
dbergman
Ny new project has a bunch of unused screws in it. I have no idea what they were used for, but while I'm redoing the floor and stringers, I thought I would remove the screws and fill the holes. What product should I use? I'm going with epoxy for the stringers and floor.
andy6374
Re: tramsome has a bunch of unused screws in it
Mix some cabosil with the epoxy. Mix enough cabosil to get a peanut butter like consistency and then fill the holes with that.
dbergman
Thanks, I will be mixing some of that stuff to install/bed my stringers in also so I'll know how to do that before I'm done. Second question. My boat had no bilge pump and I'm putting one in as a part of my project. Where on the transome do I mount the pump output?
Solittle
The bilge pump output does not have to go through the transom. Anywhere you like would be just fine (so long as it is above the water line). Mine goes throught the side of the hull back by the transom.
andy6374
Originally posted by dbergman:<br /> Thanks, I will be mixing some of that stuff to install/bed my stringers in also so I'll know how to do that before I'm done.
Mixing in some milled fibers makes for the strongest putty.
