trans trolling motor on front?
Has any one mounted a transom mount trolling motor on the front of their boat? Does some one make a bracket for this or is it even feasible? I don't want to have to buy a different troller and my boat is to narrow to mount the gas engine and the troller at the same time I don't want to have to take it off and on all the time. Any info would be appreciated Thanks.
D
DJ
Guest
Re: trans trolling motor on front?
Crash,<br /><br />Check out: www.cabelas.com<br /><br />The offer a front mount for transom mount electrics.
Dunk50
don't know what trolling motor you have but a I bought the bracket and mounted mine on the front. The control handle faces the wrong direction then. My min-kota was simple to remove one bolt and nut and rotate the handle 180 and replace the handle. It works fine.
Thanks guys I checked out mounting bracket now I think I could make something like that so that is what I'm gonna do I don't know if I can turn my handle around or not I have Bill Dance signature series motorguide 41 thrust Will check in to it today.
