Re: Transducer in the hull
From what I know of ultrasound,you may be asking for trouble using the 5200. If you do use it, the material between the transducer face and the hull surface must be kept to an absolute minimum. The inherent properties of the 5200 will attenuate the signal much more so than epoxy would. The reason for using the slow set epoxy is to allow enough time for all the air bubbles in the epoxy to travel up and away from the face of the transducer. Air also is a big attenuator of ultrasound.
