transducer
strike26
I replaced my gps and transducer from a 2002 furno to a 2024 garmin
I placed the transducer in the same position as the furno transducer, the starboard side
after reaching speeds greater than 8 knots the signal is non existent, till i reduce speed to 8 knots or under.
the hull is a planning hull with a tunnel for the direct drive prop.
I believe the prop is right hand
does anyone think its prop wash or does the transducer need to be angled more upright
Grub54891
Took me awhile to find the transducer. From what I see ahead of the prop, it should be more upright. The instructions should tell you what if any angle is a no-go.
dingbat
What transducer?
Looks like your missing the fairing block
strike26
sorry
the pic was to show the tunnel and the prop hand
the transducer is on the far right corner of the transom
Grub54891
How about another picture of exactly where the transducer is. If to far out it’s grabbing air from the edge of the boat.
strike26
sorry don't have pic
boats in water
the transducer is approximately 4' from the side of the boat
and is in the exact location of the old one
cyclops222
You have a REAL PROBLEM with locating where to put the transducer. Tunnel hulls have loads of air along the top of the tunnel at different speeds. I would mount the transducer 10" to 12" outside of the tunnel bottom edge. Near transom Where the hull is pushing down into solid water at high speeds. A picture of the rear of the boat would pin down where to mount it.
dingbat
Transducer is in fore of the tunnel, roughly 6” off keel.
Black, box looking thing, particle obscured by the top, center prop blade. Appears to be missing the fairing block. Will not work w/o one
Grub54891
Transducer is in fore of the tunnel, roughly 6” off keel. Black, box looking thing, particle obscured by the top, center prop blade. Appears to be missing the fairing block. Will not work w/o one
That’s what I thought. But he said it’s 4” from the edge of the boat on the stb side. Picture doesn’t show that.
