good day all: i have a 14ft starcraft aluminum boat(seafarer).it has a 1975 evinrude 25hp long shaft.problem is the anti cav plate is about 5inches below the keel.the transom is the cut down style.what i want to know is if i can remove the wood from the transom and install a piece with less cut down,to raise the motor.or is the transom engineered thatway for a reason.what id like is to do is replace the wooden part of the transom with a taller one,so it would be level all the way accross.could i use a solid piece of a light hardwood(weight)or should i use laminated marine grade plywood.<br />thaks in advanc for your replies Z
