Hi Everyone,
I recently bought an 88 four winns horizon 21(omc i/o) with a cracked block for what I thought was a great deal. Everything seemed to check out, transom seemed solid and the guy said he just installed a new deck. Well I took it home and went ahead and threw a new(used) 4.3 Chevy motor in it. Took it to the lake a few times and it seemed okay besides a pretty bad list to the port side. So I deciced to pull the deck, this is where I realized I F$#@& up. The deck was VERY poorly done, all of the foam on the port side was waterlogged, stringers are rotten and delaminating on that side as well. At this point I've decided I might as well do the transom too. So I pull the motor and transom assembly out and guess what.... Surprise! Transom is rotted as well!
Now for the questions,
1. Can I use polyester resin with 1708 glass to do the transom, stringers and deck?
2. Anybody have a round about idea of how much resin/glass I am going to need?
3. Would oak plywood work for this project to do I need to go with actual marine grade plywood?
4. Anyone have any tips to drilling the stud holes for the outer transom assembly?
5. Please tell me there are some easier ways to get this God forsaken foam out.
Thanks in advanced!
Thanks in advanced!
