dpagini
- Nov 18, 2015
- 41
Hey All,
I just completed an outdrive reconditioning project (detailed at the below linked post), and now I'm anticipating connecting my outdrive to my hideous transom assembly, which is not refinished. I don't mind the look, as it's all underwater, but I did the aforementioned project to protect the drive. This transom assembly can really use some similar love, and I'm wondering if anyone has suggestions on some easy options for me...?
I wanted to just give as much of the surface area as I can a real rough sanding, and I was considering just hitting these areas with some anti-fouling paint. I was told not use ablative or anything, b/c of the metal contents of those paints, and it could cause some type of galvanic corrosion. An Interlux rep at a recent boat show told me specifically to use their outdrive primer, and outdrive paint (spray paints) to do this area. Is that my best option? Those cans were a bit pricey, maybe $35/each... any cheaper options? With all the odd angles here, is painting part of this assembly even going to protect anything?
I have a similar question about my trim tabs... Can I paint these the same way?
Thanks for any help.
Dave
pics:
Dave
pics:
