Transom Bracket 1991
Fotiadis90
Hi just inquiring where i could find a transom bracket for a Force 1991 and also if it could be sent to Melbourne, Australia.
Thanks
jerryjerry05
Re: Transom Bracket 1991
What does it look like? What HP? They used 2 styles on that motor.
Post a pic.
brian66r1
I had to go to Victorian Outboard Wreckers for a replacement trim ram housing for my 1994 120Hp. It's a fair hike getting there but it got my hydraulic problems sorted. Now I've got new problems but anyway, they're in Seaford, down on the Peninsula. They have plenty of old Chrysler motors there that they strip parts off. Apart from being white in colour. Most parts are (almost) identical.
Brian
RRitt
i think 1991 still mounted the trim pump directly to side of bracket with three bolts in a triangular pattern. They should be about halfway up the bracket. If you have the triangular pump mounting then Chrysler brackets should be interchangeable. Just pay attention to steering tube as some old chryslers did not have one.
jerryjerry05
The 91 came with 2 styles of brackets.The Force one and the Mercury style.
Post a pic of your bracket.J
