IS THERE ANYONE THAT KNOWS ANY SPECIFICS ABOUT POD BUILDING. I'VE HAD ABOUT A DOZEN BUILT BY OUR LOCAL ALUMINUM FAB SHOP. THEY WORK WELL, BUT WHEN YOU ASK FOR ADVISE IT'S ALWAYS DIFFERENT.THE ONES I HAVE MADE ARE A VARIATION OF WHAT YOU WOULD SEE ON A SCARRAB, AS MOST ARE FOR TWINS. I ALSO MOUNT 30 IN. CENTER TO CENTER. AT WHAT POINT ARE YOU LEAVING TO MUCH BOAT IN THE WATER? 26 1/2 INCHES IS RECOMMENDED. I HAVE TWIN HONDA 90 REGULAR LONGS ON A 23 FT. HOURSTON. IT PERFORMS WELL EVEN WITHOUT THE TRIM TABS. I ALSO FIND THAT YOU NEED A 15 DEGREE ANGEL FOR THE MOUNTING PLATE FOR FOUR STROKES
