Transom clamp handle hole
kodibass
Master Chief Petty Officer
My transom clamp handle hole is partly stripped and I need to re-tap it, does anyone know the tap size for the omc transom clamp hole its a 20hp johnson but I think they are all the same up to 40hp. thanks
tashasdaddy
Re: Transom clamp handle hole
if the hole is stripped, you probably need to go to a larger bolt.
