transom convert I/O to outboard
joe brewer
Ok guys I need some help here. I bought this boat without realizing it used to be an I/O. It seems solid but will the boat plane and ride correcrly? It has an 88 evinrude off the back. I have attached a couple pics please give your opinions any help is greatly appreciated thanks!
H20Rat
MOST conversions from I/O to outboard or the other way are bad... A true conversion is LOTS of fiberglass work, and not just hanging a motor on the back.
GA_Boater
Joe - What boat is that? It's a tinny of some kind.
jbcurt00
try using photobucket
The glitches that continue to plaque the forum, after a software update, are causing problems w/ posting pix.
Upload your pix there, then copy the IMG code for a pix & paste them in your reply.
IMG code looks like this:
IMG]http://i1246.photobucket.com/albums/other%20people%20boats%20or%20pix%20info/hump-day_zpsac98e868.jpg[/IMG
& pix show up IN your post rather then as attachments that need to be opened:
joe brewer
I tried that lol. What this is is a starcraft holiday 18' seems to be very strong that is a steel plate running for port to starboard
jbcurt00
Your post ^^^ is empty, except the photobucket tag at the bottom.
When you view your photobucket album, there should be 12-20pix all shown at once. Under each pix is several boxes. 1 of them is labeled IMG code
Click & highlight all of the text in that IMG code box. Then right click it & choose copy. Come back to your post/reply window & paste that IMG code IN your reply.
I've never done it, but have seen that photobucket tag copy posted before. In the process of trying to copy the IMG code, you are copying something else & when posted into your reply it comes out as a link to photobucket. Which might be ok if it linked to YOUR photobucket acct. It doesn't it takes me to the PB homepage.....
Try again...
It may be easier to find/copy the IMG code if you click 1 of your pix so that it opens as the only 1 shown. Then the IMG code box should be to the right of the pix, and when you click the text in the IMG code box, it auto copies the IMG code. Then try pasting it in your reply.
GA_Boater
You just posted two pics, Joe. Inside toward the transom and #2, the motor clamp.
joe brewer
Finall!!lol it told me that it wasnt allowed thats whyi didnt think they posted. Any opinions?y
GA_Boater
Do you have a closer pic of the inside transom and the battery/tank area, the vertical piece to transom. I'm looking for bracing. Is that a piece of steel on the inside of the transom wood?
joe brewer
Yes its on the inside of the transom wood. I was thinking I would need a brace from the steel plate to one of the stringers but maybe I'm wrong
