Transom crack repair
txcopfromcali
I have a 79 Aquasport I just purchased, and just located a crack on top of the transom where the engine is mounted. What are some suggestions for a do it yourself fix. Thanks
azlakes
Re: Transom crack repair
hey tx -
i used a 3M 4200 sealer to fix and cover a seam i had along the top of my transom but was able to hide the beads with a plastic trim plate that was part of the boats features, you could prolly make a trim plate of some sorts. i also used a product called Marine-Tex to fill and fix a gouge i had on my keel. It was long and deep and this product filled the bill. Marine Tex takes a beating. Guess its depends on how you want the final look but these are two options. Just prep the surface real well before using either.
Good luck
Ayuh,....
The Odds are, If the fiberglass is Cracked,....
The underlying Wood is Rotten,+ Needs to be Replaced.....
tashasdaddy
tilt the motor up, and lock it. now shake it up and down hard, watch for flex in the transom.. if it flexes, trouble.
