Re: Transom End Cap Replacement
Hello,
I would be interested to see a picture of your transom as I am currently fixing a very similar boat as yours with the same problem. The Previous owner replaced the plywood with pressure treated. I noticed a scattering of small powdery corrosion spots, but just figured it was poor paint preperation from the factory. Then the spots grew bigger and I figured out why. with the old wood out, I took a small wire wheel on the inside and wire brushed the corroded metal out. The holes got much bigger once I busted through the powder and hit solid metal. My plan is to go over these spots with JB Weld then sand and paint the outside. How did you end up repairing the holes? To answer your question, my cap had some holes which I also fixed with JB Weld and painted. Looks great now. Depending of on how badly your cap is corroded, you might be able to do the same. If not, sounds like you may have to fab something up. Did you contact Starcraft? Keep us posted and get some pictures if possible.
