Transom help if repairable.
Erico624
Hello was replacing the bearing and piece came out. Transom is dry. Any way to repair this?
Thank you
Eric
alldodge
Could get it clean with wire wheel or other things. Wash down with acetone and use JB Weld or other epoxy. Best to just replace but understand maybe not now
Erico624
Where is the best place to get a replacement?
Try----kings propeller repair-----Good used fresh water unit may be available.----Ontario , Canada.
alldodge
Look on ebay or put a post in the wanted section on Offshore only
