TBarCYa
- Apr 13, 2005
- 781
I'm thinking of adding lights to the transom of my Maxum 1800MX so that we have some light if/when swimming from the stern at night. I've seen underwater lights for hundreds to thousands of dollars and it's not really worth that much especially considering that I'm not planning for them to be underwater but they will get wet. Basically, in the attached pic, there's a cave under the rubrail where the drive is that you can kinda see in the pic. I want to put them pointing down towards the water and if possible angled astern.
Here are links to two lights that I'm considering, both are waterproof except that the trailer light is surface mount and the other is flush mount. I'm thinking that the surface mount "trailer light" may be better since it's only 3 small holes that are required which are going to be easier to seal / repair if needed than huge holes for flush mount lights.
http://www.iboats.com/Seasense-LED-...18851522--**********.361855538--view_id.56664
http://www.iboats.com/Hella-LED-Sli...8851522--**********.361855538--view_id.258901
I just thought of a potential problem with my mounting location... Will the light penetrate the surface of the water to illuminate the drive and/or swimmers or just bounce off?
