transom mount issue
love boat
i have a 1987 bayliner with a 125 force does anyone know how to remove the transom bracket from the motor to me looks like there are 2 long bolts an upper one and a lower one do they slide out any advice would be appreciated
jerryjerry05
Salt or fresh water??
The 2 long bolts.
​One is a tilt/ pivot bolt.
This has been greased and "might" come out???
​Part of this bolt is exposed and possibly corroded and might need cleaning to get loose.
​The bottom "lower tilt shaft" will probably not be easy if it comes out at all.
​You'll probably need a torch and a hammer and brass drifts to knock the bolts out.
Why take it apart??
love boat
kind of figured that ends up dont need to long story not worth getting into thanks again for the info
