I have a Vectra with a glass modified V and a pontoon type deck. I have a 115hp Suzuki . My transom overhangs the bunk boards by 4 inches. I always use a transom saver when the boat is trailered. I moved the winch post up to lessen the tounge weight on the ball which inturn moved the transom back off the bunk boards. I travel with the motor mostly down with the transom saver. Question: will it hurt the transom to be off the bunks by 4 inches? I may be able to reduce it from 4 inches to 2 inches by moving the winch post back a couple of inches and still have good tounge weight.
thanks a bunch.
Billjd
thanks a bunch.
Billjd
