Transom Paint
kkwedell
I just repaired the transom on my bass boat from the inside, but there were some holes and chips on the outside skin that I had to fill. Looking for a grey paint for the back. It is gelcoat now, but I do not want to try and apply that much gelcoat area. I would just go ahead and use a topside paint, but maybe a couple times a year we go camping and the boat stays in the water/docked for up to 5 days at a time. I thought about interlux brightside (if it would last that long in the water?), perfection 2 part (will it last long enough for that much submersion?), and vc performance (but I need a light grey and it only comes in white). Looking to spray it on as thats what I have experience with.
welcome aboard
at the top of the forum are stickies. look at the 4th sticky down which has all the restoration links. look at link #19
Chris1956
Not sure Brightside will last for 4 days submerged. Perfection will last indefinitely submerged.
Gelcoat is not that hard to apply. You can spray it with the correct orifice (2.0MM?) It can be rolled as well.
Chris1956
Most one part urethane paints are labeled for top side use only. They do not hold up when submerged for an length of time.
Two part urethanes are made for below the waterline use.
