Transom Plate and Front Motor Mount not quite parallel MC140
Alumarine
I'm in the process of replacing the transom in my Sylvan with MR drive 140hp.
While test fitting my Gimbal Housing and Transom Plate I noticed that my transom plate and front motor mount pad are not quite parallel.
I was wondering how critical this is?
I drilled 1/2" holes through the transom. If I enlarged them to 9/16" I can probably rotate the plate somewhat. At least get it closer.
transom plate
front pad
Ayuh,..... It's Not,.....
Yer motor is a 3 point mount,..... the differences in angle will cancel at the 1 front mount stud,....
Alumarine
That's awesome, thanks Bondo!
I'm too tired to understand but it will probably make sense tomorrow.
In any case, I won't worry about it.
