GSPLures
- Sep 3, 2019
- 564
Hope you all are doing well. My transom plate cracked on the bottom, the transom was rotted when I bought the boat previous owner torqued it and must have cracked it. The bottom piece fell off when I removed it.
I am looking for a replacement and I believe the part # is 65550A2 the stamped number on the plate is 65550. When I searched that number I came up with a couple parts that look identical but the stamped number is 79000
I still have the piece that broke off but figured tig welding it would be near impossible due to it breaking at the bolt holes.
Can anyone confirm if this is the correct replacement part my motor is a 1973 140 I just want to be sure due to the different casting numbers on the plates.
