johnny be good
- May 16, 2010
- 48
I am just starting to do a transom replace on a 28' Chaperall cuiser merc. 350 engine alpha 1 outdrive. I disconnected the engine and shifted it foward as far as I can to get to the inside transom plate I am not able to lift engine completly out which would be nice but I can see where the exhaust tubes mount to the transome but I can't tell If they are mounted to the transom plate or just to the transom alone. My question is do I need to remove the exhaust tubes before the transom plate or will they come off with the transom plate in one peice. I can't tell if the exhaust tube are held with a wood screw into the transom or machine bolts into transom plate all I can see are the 12pt. bolt heads. I will later add a question on lineing up the engine and outdrive. I am not disturbing the outer skin so I will have all the original mounting holes and same with the engine mounts I marked everything so it can be put back in place as close as I can. Thanks for reading. John
