Transom Repair After Sea Drive Removal
J. Fenn
The boat is a 1984 Wellcraft Sportsman 248. It was originally equipped with twin OMC Sea Drive outboards. The installation of these engines require that two openings for each engine be made through the transom. There are some photos on this webpage that show the shape of the openings after a Sea Drive unit is removed. The photos are not of my boat, but the photo accurately portrays the openings I have in my transom.
http://continuouswave.com/whaler/reference/seaDriveConversion.html
Now for the question. What is the proper procedure for filling these openings after removal of the Sea Drive units? I conjecture that the process would entail the following:
1. Preparing some layers of plywood, epoxied together, that are roughly the size of the opening and depth of the existing plywood layers.
2. Removing a thin layer of the material around the inner surace of the opening to remove contaminants and achieve a proper bond.
3. Wrap the plywood fill pieces with some chopped strand and wet out with epoxy. Wet out the inner surfaces of the openings with epoxy as well. Force the plywood fills into the holes so that epoxy and chopped strand ooze out, the voids are completely filled, and the plywood fill pieces are flush with the transom.
4. After curing, layer both inside and outside the transom with some glass mat and epoxy.
5. Fair and gelcoat the outside. Lay more mat over the inside and paint with bilge paint.
I would be most appreciative for any sound advice on how to perform this procedure, or referrals to any literature that describe the proper procedure. Many thanks.
Joe F.
ondarvr
Re: Transom Repair After Sea Drive Removal
What you're thinking will work, but the gel coat won't stick all that well to the epoxy.
You can use epoxy or polyester resin, it won't make that much of a difference.
If you cut the wood inserts for a close fit, there won't be any room for mat to be wrapped around it, so you can just use putty to set them in place.
tashasdaddy
before i give my opinion, what are you repowering with and how?
ondarvr
That info would help, I was assuming a bracket would be mounted.
J. Fenn
You assumed correctly. I will be adding a full transom flotation bracket and repowereing with twin outboards of up to 200 hp each.
I failed to mention how I planned to fill the bolt holes. I had planned to drive sections of epoxy-coated wooden dowel rods into those after reaming the holes slightly.
Good point on the gel coat not sticking. Do you foresee any issues with using polyester resin for the mat covering the outside surface?
ondarvr
It will work fine, just don't leave any excess epoxy on the surface where you want to use polyester. Either product will work and the cost won't be that much different because the area is small.
tashasdaddy
would like to see some backing larger than the cut out, on the inside of the transom. that plug is all thats keeping you from sinking.
ondarvr
He talked about glassing inside and out in the first post. There will be little or no stress on the repaired areas unless a bolt for the new bracket goes through it (the repaired area). Your transom is already designed to have big motors hanging off it, so it should be beefy enough, but without seeing it, there's no way to be sure.
Ayuh,.........
As small as those holes are,..... I think Backers are overkill......
You could do it by cutting the plywood plugs Loose,+ installing them with a liberal supply of Epoxy Peanutbutter,.........
Fill the holes out to the level of the original Wood,......
Then switch over to Poly,& Glass to cover the bilge,+ to fill out the transom's skin.......
Then of course,.... Fair,+ gelcoat..........
J. Fenn
Thank you all. I will post photos after engines are off but before repairs are begun to confirm your opinions. The full transom bracket should distribute the load more evenly than the Sea Drives, but I will be careful to avoid bolting through any of the repaired plugs, or if I have to, I'll consider the wisdom of backing material on the inner transom wall.
Joe F.
Reelized
When I replaced my seadrive with a bracket the one I bought had a solid front panel.There was no need to fill the holes in my situation just some 5200 on the mating surfaces, bolted together and no problems.It depends on who you get your bracket from,if their's is full face or just flanged.Try googling D&D marine and check their brackets.
