samo_ott
- Jun 18, 2006
- 5,125
Has anyone done this before. I just got a boat real cheap that the transom was really weak. So I bough some 11 gauge metal pieces (1/8") and got them cut to size. Painted white on the outside and primer on the inside. Bolted and spot welded the pieces on to the old transom and it is now rock solid. I can see a long term problem with this as it will still rot inside and the metal will eventually rust but it seems to be a great short term cheap fix. Any comments on the procedure?
And I posted a lot of pics here:
http://www.ovhi.ca/transom/transom_01.JPG
There are 13 photos here of the process from transom_01.JPG to transom_13.JPG
Steve
Steve
