I am preparing to replace the transom on a 1980 MFG Piper 1500 outboard. The transom is well rotted and no doubt that it needs replacement. It is an inch and a half thick, however I am not sure if that thickness extends to the outer corners of the transom. I can see the transom from inside underneath the splash well and from my observations it appears that the 1.5? thickness may only extend partially.
See sketch of what I think that transom may be shaped like as if you were looking down from the top of it.
My question is could this possibly be the shape and was this a practice that MFG employed on some of their models. I am trying to decide what approach I want to take before cutting into the boat such as removing the splash well, separating the deck from hull, etc.
Thanks for your help.[/B]
