Hi Everyone,
I am new to boating and bought a 92 Four Winns 200 Horizon with an OMC Cobra 5.8. I looked over everything before I bought and it checked out. I felt the transom pushed on it near the transom bracket and all around. It was good. I got it in the water shortly after I bought it and was taking on some water. I had my marina shop guy check it out and it it leaking around the garboard. He pulled it out of the water and removed the garboardand there is signs of rot, chunks come out on the finger. I have used a hammer to tap around trying to figure out how high the rot goes and if it goes into the transom mount and it doesn't sound like it. I what I want to do now is drill a couple of holes and check that way as well. What is the advice on how big of a drill bit to use. I am hoping to do a patch job with filler and resin around the garboard. Reseal the garboard and finish out the summer if the transom mount isn't rotted. I plan on either taking it in this winter and getting it repaired or doing it myself to save 4k. I can post a picture of it later.
Devlin
Devlin
