transom seal kit 1985 120 horse mercruiser
jeff13601
Does anyone know the numbers of the transom seal kit for my boat. I believe it is 18-8206 but I would like to know for sure. Also does 146.00 seem like a good price? Seems good to me
Laddies
Banned
Re: transom seal kit 1985 120 horse mercruiser
Ch your drive serial number, I think you need 18-8205, also while is apart ck the shift cable carefully--Bob
Laddies
Banned
That makes it a MR unit and it takes 18-8205, the outter hsg. on the cables tend to crack and break right at or near the nut that holds the in the bell hsg.--Bob
jeff13601
I looked at the number best I could and it looks like 6893455
jeff13601
Thx. I believe the difference in the two is that the 8205 has exhaust tubes
In My book you need 18-8205,..... 18-8206 is for an Alpha Gen II...........<br />You'll Also want 18-9031,.... Bellows Adhesive.... Gotta Have It......<br />18-2600 is the Lower Shift Cable kit......
jeff13601
Bondo, would you get the lower shift cable kit also?
Laddies
Banned
The 18-8205 both ends of the u-joint bellows have clamps on Gen 2 on 1 clamp and a wedge ring
jeff13601
Ill order it then. Allways willing to listen to experience
Ayuh,.............<br /><br />I wouldn't go that Deep into it,+ Not Change It.........
