Transom seal replacement
Larry E
I am going to be replacing my OMC transom seal tomorrow. What kind of sealent should I use between the rubber and transom?
Larry E
boatnut74
Re: Transom seal replacement
3M 4200 or 5200 should work just fine.
Larry E
I am told that the 5200 is very permanent in that it is more then difficult to remove later on. Is the 4200 like that?
Ayuh,... 4200 is like 5200, only removable...
Howard Sterndrive
I like the Permatex Copper, mainly because my boat is orangy red. Most boat builders used no sealant. Any RTV fine. I would think 4200 probably better than 5200. You don't need bonding, the clamp holds it.
Larry E
Ayuh,... Define Better....
Easier to apply. The 5200 which I have seems to not be very easy to move around. And should I be able to remove it down the road in case I would need to replace the seal again?
Zyen
i've used Silicon RTV with no problems.
Larry E
That is great advice. My boat is orangy red also so Permatex Copper it is...Trailer restoration.jpg
