Hi everyone, I need some help, Recently bought a used Zodiac. I brelieve its 11' long. It has a bad transom, The plywood has rotted. It seems to be mounted to the tubes by a formed plastic cuff. The cuff looks like it was heat molded into the plywood ( It flows right through the drill holes in the plywood) Can i get a new transom , If so where? Will it come with the plastic cuffs? Can i debond the old cuffs from the tubes? Any help would be great. Thank you, sam
