transom
angela22980
we are replaceing our transom we are using treated plywood.when we put it all togeather the resin didnt stick the wood togeather and the wood was damp when we took it part to redo it.what do i have to do to get it to stick and get hard.the plywood wouldnt stick to the shell of the boat eather please help
F14CRAZY
Ensign
Re: transom
Plywood may need a couple months to dry enough for resin to stick to it
tallcanadian
Re: transom
What are you using for resin and fiberglass? Some resins won't stick well to treated plywood. Your better off getting either marine plywood or exterior plywood.
Re: transom
Ayuh,... Put your plywood somewhere Hot to Dry it... Then use Epoxy instead of polyester resin....
