Re: Transome/bilge drain plug???
Yep! Brass-lined holes with big wine bottle stoppers in em. A season hardly goes by where you dont get to see at least one boat causing a boat launch traffic jam, have just launched without putting the plugs in first.
It is soooo much more entertaining when the person holding the dock line finally figures out hey! something is wrong and I know what it is!!! and plugs are in the glove box of the truck that just pulled away to go park the trailer
<br /><br />The 18-ftr has the drain holes in the floor, right up against the transom. Normal activity in this boat always brings water into it. The boat is designed such that while underway and all the water flows up against the transom, I can pull the plugs and let the water drain out. The plugs have to be back in before the boat stops, or I end up in one of those sneaker wash/live well combos.
Not all boats are designed for draining while underway. If you dont know if your is, dont try it.
Btw: you are right, the big boat has 2 stern scups and 2 p/s drain holes w/plugs, all at floor level.<br /><br />Having the drain hole 1-1/2 inches up the transom probably isnt doing you much good as far as getting the water out of your boat. You should be able to move the hole back to where it belongs. The Marine-Tex (or equiv expoy system) should be ok for what you are doing. If your transom is 3-inches of ply/glass, it is unlikely you need to reinforce the transom by re-glassing the old hole, although it is not going to hurt to do so. Obviously, it is important that you completely seal all of the transom wood.<br /><br />What do you think about sealing up the old hole altogether and installing 2 new drain holes, one in each corner, since it seems that is where the water ends up anyway? Overall, it might be less work to drill 2 new holes than grind out 1 old one. Just a thought.
