fmt2bx
- May 27, 2015
- 217
Hi,
New to Mercruiser I/O here.
It is a 1997 Mirage with a transplanted 5.7L TBI. I have pictures of ECM, Coil and distributor. The motor is matted with an Alpha 1 Gen2 Merc drive, I need to wire the Interrupt switch on the shift plate... I am at a complete loss.. Did a lot of reading but , as you can see, the coil doesn't have a + and - studs, it's got 2 (2 wires ) plugs. Some more reading suggested that I need a Normally Closed interrupt switch. Mine is normally open (of course.. ) and it is the new type, (not roller type). and that the switch would have to be connected to the coil somehow...
Anyway, I am reaching out to the gurus here. I really don't want to start experimenting and frying things.
Thank you!
Fred
Motor
Coil
ECM
Distributor
Shift plate
Thank you!
Fred
Motor
Coil
ECM
Distributor
Shift plate
