Transum help ?
debt finder
hi , i have a 82 sea ray sundancer fiberglass hull . i just bought a nice set of underwater lights that mount to the trim tabs and was wondering what is the best way to run the wires through the transum and get a water tight seal ?
JoLin
Re: Transum help ?
I don't have underwater lights (maybe someone else will answer), but I can't imagine why I'd consider wiring them through the transom below the waterline. Don't you want to run the wire up the transom toward the gunwale, and then drill through?
rndn
Re: Transum help ?
I agree with the above post. Whenever possible do not drill holes in your boat below the waterline. A hole with a screw in it is one thing, but not a hole for wires. Why not run the wire above the water line for the larger hole for the wires?
