Trawler heating sysytem
Jauncy
A bareboat charter outfit in Anacortes lists a 34' CHB with a heat pump as the cabin heat source. I've not heard of such. What is the motive power for this heat source? 110? 12V? Diesel? Both a.c.'s in our motorhome have reverse cycyle heat pumps on them, but these require 50 amp. shore power or the 7.5 kw genset to run effectively. Thanks for your help!
airman
Re: Trawler heating sysytem
Most likely reverse-cycle A/C. The power souce would then be shore power or the gen set. Not really a very good system unless you like running the generator all night.
