Trent , air boat engine
clanton
After I id engine, can you help with some specs, for carb, fuel pump, compression numbers, checking the mag.
Trent
Re: Trent , air boat engine
No problem....... Give me all the numbers off the data plate. Also all the numbers off the mags. Carb... And make. Most likely carb will Be a Marvel and the mags will be Bendix or Slick.<br /><br />The compression can be done the direct way that your used to with boats. However its not the best way. They should be within 20 percent of the highest cylinder.
