Re: Tri hull handling
Take it for a test run. Not all tri-hulls slap, there were good designs and bad designs. The way you can sort of tell how it will handle is to look at the transom. If there is pronounced V at the transom, it will handle better than one that is more flat at the transom. Click my link, the first picture is of the transom end of my rig, if it looks like that, it will handle well. Mine handles very rough water as good if not better than a V-hull. You have to try it out to know for sure. you should always try to hit wakes at a 45 degree angle if possible. I don't bother with that myself, my tri-hull plows through the wakes with just a small bumping, it has never slapped. Good luck....
