triangle question
FSHKPR
Ensign
if i want a triangle that has one side of 24 inches and the other two sides are 16 inches? what are the angles needed to achieve that? and how did you figure it out? thanks
Pony
Re: triangle question
Ok its been awhile since I have done math so hang with me. I think your biggest angle has to be 97.18 degrees and the other two have to be 41.41 degrees. Im sure someone can correct me.<br /><br />I used the law of cosines. <br /><br />CosC= (a^2 + b^2 +c^2) / 2(ab)
Xcusme
Give that man a cigar!!! Spot on !! I did it by figuring 2 right triangles back to back.
Paul Moir
I do it the handraulic way, and break it into two right (90 degree) angle triangles. Draw your triangle with a 24" base and 16" sides and then draw a line right down the centre.<br /><br />Now you can use the trig functions on your scientific calculator to calculate the angles. We'll start with the lower left angle. You know the line that's not part of the right angle, called the hypotenuse, is 16". The line adjacent to the angle we wish to find is 12". Now we must select the correct trig function.<br /><br />The selection depends on what numbers you know. Here's the formulas:<br />angle = arcsine of the opposite side divided by the hypotenuse<br />angle = arccosine of the ajacent side divided by the hypotenuse<br />angle = arctangent of the opposite side divided by the ajacent side<br />(I memorize this with the "word" SohCahToa)<br /><br />Since we know the adjacent and hypotenuse lengths we'll use arccosine. Divide 12 by 16" and we get 0.75. Now to get the arccosine, first make sure your're calculator is set to degrees (DEG as opposed to RAD or GRAD). Enter 0.75, next click the 2nd, or INV(ert) button to make it arc, and then hit COS(ine). It should spit out 41.4, which is the angle.<br /><br />Now to get the other angle, we'll use a short cut. All the angles in a triangle add up to 180. We know the right angle in the middle is 90, and we found the bottom left angle is 41.4. So 180 - 90 - 41.4 = 48.6. <br /><br />Finally it's time to put it all together. The lower right corner of the triangle is the same as the left, so it's 41.4 degrees too. The tops are the same too, so each of those is 48.6 degrees. Since clearly they're beside each other, simply add them. So the angle up there is 97.2 degrees.<br /><br />I hope that explains it!<br /><br />EDIT: Longwinded and late. :D
KRS
Banned
Triangle man, triangle man, doing the things that only triangle man can....
FSHKPR
Ensign
hey thanks alot those figures worked out great! i am building a flag display case like this one, for my aunt. the flag was from her husband who recently passed away.
united-states-flag_1888_2750062
ndemge
Triangle man, triangle man<br />Triangle man hates particle man<br />They have a fight, triangle wins<br />Triangle man
KRS
Banned
Originally posted by NoelMG:<br /> Triangle man, triangle man<br />Triangle man hates particle man<br />They have a fight, triangle wins<br />Triangle man
:) there's at least two of us, I wondered who bought the other album :)
--GQ--
Originally posted by TexomaAv8r:<br /> Aren't those just 45*/90* triangles?
No, those are obtuse triangles. They can only be solved using The Law of Sine/Law of Cosine. Another way would be to split the traingle into two smaller traingles. Then using congruent angle thereoms to prove they are the same as the larger.
