bobgritz
- Sep 22, 2009
- 185
I'm only getting a trickle of water out the p-hole of my '83 15hp ... up until now the head would only get warm to the touch but now you cannot hold your hand on it. I checked for obstructions in the p-hole and the p-hose but they were both clear. I blew air into the p-hose was able to blow throw it easily.
Next I dropped the gearcase to check the water pump and it looks in very good shape with no obvious imperfections.
I attached a short hose onto the pipe that attaches from the pump to the cooling system (see pix below) but when I blew into it there was a lot of resistance (and I mean a lot). Perhaps this is normal but I would have thought the passageway would be wide open and easy to blow through.
I was going to either flush this pipe with water or compressed air but before I do any damage I thought I'd check in with the experts! Anyone familiar with just how much resistance I should expect and is flushing it a good idea. BTW, what pressure (air or water) should I use?
