JasonJ
- Aug 20, 2001
- 4,163
I have usually been more for trim tabs than hydrofoils, I think trim tabs are a better way to get it done, but the guy who is renting the other side of my dock from me put on an interesting hydrofoil. His buddy put the same kind on his boat as well. These guys could not say anything bad about the thing, and these are new-ish boats, one a Chaparell and the other a Chris Craft. Since my boat is old, skanky, and has no power trim to speak of, I thought I would try this thing out. It is an Attwood plastic two piece job that is more of a gullwing configuration. They stick up at angles, the theory being that once on plane, less of the surface is in or touching water, reducing top end speed robbing that flat foils cause. I was a bit skeptical, but $32 isn't a lot to spend on an experiment. My rig has always taken a little bit to get on plane, but when I am by myself it never bothers me. When I have other people in, it is noticeably more difficult to get on plane. It took ten minutes to install them, once complete I did my decarbing.<br /><br /> Put Seafoam in 3/4 gallon of gas/oil mix, and ran the outboard at 3000 rpms until it was all gone. It was a smoky, stinky ordeal, but it was interesting. The first half of my brew burned pretty quick, but as the motor was running, it started taking longer for the second half to burn off. Rpms staying the same at 3000, it took almost three times as long for the second half of my brew to burn off as it did the first half. I also noticed that the motor quieted down a good bit. Once complete, it was time to take it out for a test run.<br /><br />The engine ran noticeably smoother, less shake, and not as noisy as I idled out to the lake. Once I attempted to go on plane, the boat went on plane dramatically quicker, and with less throttle. Usually I floor it to get on plane, then bring it back to 4000 rpms for cruising. I deliberatly only brought it up to 4000 and it went up on plane very quickly and rpms climbed. I can stay on plane at a slower speed, but that wasn't what I was looking for. Top speed is the same as it was before, the foil is not leaching anything. The boat turns differently now, the stern doesn't want to burry itself like it did, which I actually liked that, it felt more secure. Now, because of the lifting of the foil, it does not squat in tight turns, but it still turns sharply and leans very well, like it should. The decarb didn't increase the power (I didn't expect it to), but it did make the motor more quiet, and it was smoother and sounded better at any rpm. It was a healthy 35 year old engine before, now it is better. Just thought I would share my foil/decarb day...
